Thaddiusjude
I just got back from China yesterday so today is my first chance to open the inverters. So far everything is looking really good. I’ll update as I get them installed this week.
You went with the ABP, correct?I just got back from China yesterday so today is my first chance to open the inverters. So far everything is looking really good. I’ll update as I get them installed this week.
This is very exciting!! The first ABPs in the wild (documented on this forum at leastI’ll update as I get them installed this week.
I think there was something floating around a while back but newer models would make it obsolete.Is there an srne cheat sheet somewhere that delineates the models and their abilities/pros/cons?
That's correct.You went with the ABP, correct?
They look great.
Fwiw, Sams Club had/has a 12k window AC, Inverter, Midea, not the U, on sales for $249.That 12k unit I have would probably be ideal because of how small it is as far as fitting it on the wall. But with 3 inverters I'd want one of the 24k ones I have but you may now have enough wall space for that one.
Being inverter style units the 24k doesn't normally use any more power than the 12k surprisingly across an entire day of use.
My Dad bought 2 of them.Fwiw, Sams Club had/has a 12k window AC, Inverter, Midea, not the U, on sales for $249.
I had him convinced to go with a mini split until, even though he didn't need heat, until I saw that price.... They are back up to $300 now.
I bought one of these. It has been fantastic. Rarely runs higher than 690 watts.Fwiw, Sams Club had/has a 12k window AC, Inverter, Midea, not the U, on sales for $249.
You need to drill the bars and ensure those are copper and not brass. Second, the base has to be solid and the studs held well in place. More than one member bought busbars off Amazon and found the bars were brass and the studs heated up and pulled out of the base.View attachment 303170
Found some decent inexpensive parts on Amazon for my busbar setup. This will be for the 2 Inverters and 4 batteries to start.
Panel
Bus Bars
Drilled them, they are tinned copper. I'll post pics.Are you sure those are copper and not brass?
Agreed, I have tested. They are tinned copper just as described.You need to drill the bars and ensure those are copper and not brass. Second, the base has to be solid and the studs held well in place. More than one member bought busbars off Amazon and found the bars were brass and the studs heated up and pulled out of the base.
The 600A busbar shown here was recommended by another member here. It is copper, I drilled one. It is built well. It is on Amazon.
Lots of thick smoke from the wildfires out west has made the midwest very hazy even on "clear" days.Weather has been kicking my butt this month. I have been running the eco-worthy 60 amp charger off the dryer outlet nearly daily to keep things going. Can't get any decent production between rain and clouds. I was so looking forward to spring/summer to see what all of the panels I had added could do but its been pathetic so far because of the weather.
A lot of lightening!! That used to be my old stomping grounds - the panhandle of Florida and lower Alabama
