I posted a similar question in another area and think I should have put it in here. Here is the story, I bought an all-in-one charge system/inverter. The internal charge controller is 48 volts. The inverter is 48 volts. I am looking to save quite a bit of money on the batteries and found that hooking four 12 volt batteries in series is far cheaper than buying one 48 volt battery. The batteries would all be lithium and the brand would be on the cheaper end like a Chin's or similar. The four stacked 12 volt batteries produce the same amount of watt hours as the single 48 volt battery and save $1,000 - $2,000 dollars in the process.
Here is question. Is it ok to charge the four 12V batteries which are tied in a series using the 48V charge controller?
A person who responded to the other post said, "Maximum of 51.2v doesn't make any sense for a 48v system as that would be 12.8v per battery or 3.2v per cell which is not enough to charge the battery. That would be nominal mid state of charge voltage. Max full charge would be 16x 3.65v = 58.4vdc". I am grateful for their response but am very confused by it. Can anyone help me understand what I might be missing?
Thank you all very much for your help!
