Ok, that makes more sense, the lra is only on the washer motor, not on the heater. So, the 3 times load will only be on the motor portion.
However the dryer has a larger heater and a motor as well.
You could get an 8000W all in one inverter that will use batteries then switch to the grid when they reach a low state of charge.
Now, batteries will be a big part of the cost here...
You need to find the total kWh used each day.
