Starlink from 48 volt rack battery
@HighTechLab
That’s the question. How to run the Starlink with DC to avoid inverter losses 24/7 and allow VRM.
Starlink provides a DC to DC adapter to provide exactly the voltage the Starlink dish wants. But the DC to DC adapter seems to top out at 48 V input. According to the specs.
I think Starlink tech support is saying it’s fine to run it.
That would provide a complete solution to this issue. Buy the DC to DC adapter, run it from the batteries. Done.
The other possible option is to run the Starlink directly off the battery with no DC to DC adapter. Then the question becomes whether the variations in voltage will have an adverse effect on the Starlink dish.
Antron thought this might cause issues.
I think Starlink tech-support is saying that this option is fine also. But I doubt they understand the server rack voltage range.
This is the voltage chart. I provided to Starlink tech support when asking my question.
I think it would be great to be able to pin this down once and for all. They’re surprisingly little information out there.
I’m willing to buy the DC to DC adapter and give it a shot. I’m a little less willing to try running the Starlink directly off the battery as it’s a little pricey to burn it up.
Ever so slightly off thread here, but y’all that haven’t committed to the Gen 3 and its high power consumption, you should take a look at the Mini with a down converter.
We've had a member make this work before.
Great thread. Thanks!
You could make external TVS overvoltage protection circuit that can absorb the surge without threatening internal surge protection circuit inside the dish. All it takes is a fuse in series and appropriate TVS diode (or multiple in parallel) from fuse output + to - on the dish side. This way if the surge happens then TVS clamps it or blows the fuse.
Thanks for your comments on starlink power input. I was thinking of powering a Starlink Mini from RV's 12v battery, but using an aliexpress boost converter to step up the voltage to say 36v so I could run a pretty long (30m+) power cable for those times it needs to get out from under tree cover. Would the capacitors in those sort of boost converters absorb a little of the spike of a BMS shutting off when a solar charge controller is doing the charging? I can see that happening fairly frequently but I have no idea the magnitude of the spikes created in a 12v system.. Would rather not fiddle around to spec/buy TVS diodes (since I have no experience with them).
That should work just make sure that boost converter can handle starlink dish peak current. May have to rig up small 36v or 48v booster battery on the output of dc converter to absorb current peaks from the dish and serve as brownout protection.
Thanks! And thanks @MarioP for the note. In the end I used a voltage drop calculator and decided 36v should work, brownouts notwithstanding, and be preferable to my kid potentially grabbing a handful of 48v from and complaining about it forever.
So can I power my Gen3 starlink and dish directly from my 48v rack batteries? Don't see a definitive answer here...
Or do I need the Starlink DC-DC converter?
It’s not definitive. But it’s maybe leaning towards probably. Since you have a Starlink dish, you can email customer service. It was a while back but I recall they said it would be ok. I think. Maybe.
