First post from me this has been a wonderful resource for learning. Want to make this somewhat of a build thread. With the width and depth of knowledge available here hoping to get any insight I can.
Wife and I are in the process of rebuilding 2002 38' 5th wheel. Nearly a total rebuild from water damage. Have re insulated with foil faced EPS 2" plus air gap in the walls 3" to 4" plus air gap in the ceiling. So from r5ish/ non existent all around to r12 ish in walls and between r18 and r24 for the ceiling
The physical structure is nearly complete and I'm wanting to address electrical issues before I put all the interior walls back up.
When I bought the trailer it had a FLA 6v battery that was bone dry no voltage wired in parallel I thnk with a 12volt AGM battery that showed 11.1v. Thankfully both batteries were fairly new and I was able to swap them out for a matched pair of new AGM 110ah 12v for $68 for now. Will be swapping to LFP with Michael down the line once I can get a baseline energy audit done.
The hydraulic pumps for the slide and the leveling jacks both seem ok.
The A/C unit control board "functions" eg lights come on but doesn't seem to actually control the rooftop unit. It cycles on and off on its own no matter where the switches are set, so fried i think. Anyone have a particular stand out A/C unit/s they'd reccomend? Currently using one of the crappy 9kbtu portable units from my shop its enough to take the edge off but not enough to actually keep it cool.
The 45amp converter seems to max out at 20ish amps. When I attempt to pull more the lights start to pulse and fans get slightly odd. Unsure if its a wire size issue, if the converter is about shot from trying to charge a 9v? Battery or both. Basically i can either charge batteries or run lights and fans but not both.
To cap it off the smoke, CO, and LP alarms were all unplugged assuming the weird voltage from the 6v/12v combo they constantly would go off.
The 3 way fridge does operate in all 3 modes.
The oven functions but pilot light has to be manually lit. Same for the burners the spark ignition doesn't work but can be lit with a grill lighter.
Any one think of any other control boards/ or functions I ought to go test? Last 2 I havent tested are the water pump and hot water heater waiting on some PEX fittings to come in so I can flush the whole fresh water system then test.
For air flow the original trailer had 5 unpowered roof vents and the range vent. Have switched to a single powered one in the bathroom with plans to switch to 2 additional powered vents in the "garage" and the master bedroom. Think I will be ripping out the other 2 vents for additional solar space. I have added 3 8" radiator fans in one of the former compartment doors on a dpdt switch for additional venting either in or out. To any offgridders or RVers are the fantastic fans really worth that stupid high $$$ vs me slapping a $40 14" radiator fan up top.
My kwh meter should be in today so I can start doing an energy audit for solar and battery sizing. Can't wait for this part to get rolling.
The 4kw onan gas generator ran at some point in its life its up for testing sometime this week if I ever finish building the new countertops.
TL:DR for today
Hi
what all may be damaged in an RV 12v system that was attached to a 6v and a 12v battery wired in parallel.
Any offgrid/boondocking experience/advise is very welcome.
TL:DR for today
Hi
