I have a set of questions relating to incorporating a new starter battery (the Dakota Lithium 12V+135ah: https://dakotalithium.com/product/d...ar-truck-battery-plus-deep-cycle-performance/) into an existing Renogy LifePO4 300ah battery bank.
Wife and I have been living in our 2021 Tacoma for 14 months now. We power a 12v fridge, and Starlink (via their router) 24/7, and we sit still at camp for 4 days in a row. Looking into adding this dual purpose starter battery to help aid the powering of a new induction cooktop.
Existing setup:
- (3) 100ah Renogy LifePO4 12v (Bluetooth, but not self heating model), wired together in parallel for 12v output (can't find on their site anymore).
- 400w solar (maximum I can fit) Renogy panels wired in parallel also (https://www.renogy.com/renogy-100-watt-12-volt-monocrystalline-solar-panel/)
- Renogy 50A dcdc with mppt charge controller. Solar input from roof, and alternator input from the front of the truck.
-2000w inverter (will be going to 3,000 when induction cooktop is incorporated), 12v DC Bluesea fuseblock, etc.
New Addition:
- The DL 12V+ 135ah battery listed above, with Victron smart shunt, in replacement of my now slowly dying lead acid battery that came with the truck.
Desire:
- To incorporate this dissimilar battery into my existing battery bank (safely!), so that I have (4) batteries in parallel to draw from when set up at camp.
Note:
- I am willing to step away from the Renogy Charge Controller (Victron comes highly recommended by friends) if another product is more intelligent/better equipped to incorporate these two batteries.
Questions:
- If connected appropriately, will all (4) batteries drain down together, like my (3) batteries currently do?
- The DL can be charged at 135a, while the Renogys' are limited to 50a (max), but share a 25a (from alternator) charging rate. With this in mind, I can't simply wire in the DL in parallel or else the three batteries will overcharge, correct?
- If what I typed above is correct, is there an Automatic Transfer Switch type product that will automatically link the (4) batteries together when the truck is off, but separate the DL from the (3) in the camper when the truck is turned on?
- What else am I missing? I got a great deal on the basically new DL from a friend, and an extra 135ah of battery in the same space as my current starter battery is nice to think about.
Pardon my lack of experience/intelligence in this area. It was fairly easy to put together the current system that powers my day to day life, but the addition of this dissimilar battery into the mix creates hesitation.
Thank you for your help.
Existing setup:
New Addition:
Desire:
Note:
Questions:
