I hated doing it but today I very sadly cut down a large spruce tree which I planted 23 years ago. I knew I would likely have to from the beginning of my solar project but I naively thought it might not be so bad. I wanted to wait and see but now the numbers have confirmed it. I was loosing at least 30-40% production after about 10:30AM to around 3:30 PM over the month of October and it was getting worse as the sun is getting lower.
I am actually running my entire house load with the 10 panels (5400W) during most of the day when the sun is up with the exception of when my 4500W electric hot water heater kicks in or the when the furnace and well pump happen to run at the same time. So far the graph on the Sol-Ark15 is showing my total month load at 208 KWh with solar providing 79.5 kWh or about 38%. Things should start to improve a bit with the tree removed.
I set up my house to run on the batteries overnight, but after a couple of days I found the 10 panels would not provide enough power to run the house load and charge the batteries back to 100% during sunlight hours. I ended up using the same power having the grid charge the batteries in the evening than would have been used to have the grid power the house loads overnight. This will change once I add the next 14 panels with 7000W added to the mix.
The new ground mount/dog run on the other side of the house for those new 14 panels has come along pretty well but I decided I just didn't have enough time this fall to finish the rafters and rails & panel install before the snow fly's. I am working solo on this project and working up off the ground when it's cold is not fun. I hate working in the snow which is scheduled to arrive tomorrow. That is my spring project for next year as soon as the weather breaks. I hate loosing that solar potential over the next 4 months, but thats the way it goes. The new panels, rails and clips are all sitting in my trailer in my shed ready when I am.
