cmtodd1000
- Jul 26, 2021
- 1
Hi everyone, looking for some insight. i've got an 18' hybrid with a 24 series 12v agm battery with a 79 AH rating.
i've just installed the AiLi battery monitor (incl 350 A shunt) and will be adding the renogy eclipse 100w panel with the 20a charge controller. We're going out for a few nights without shore power, so i really just need the 2 way fridge and propane detector to work, i'll be using USB lights, and don't need to worry about the water pump...
when i'm connecting the solar panel with the alligator clips, do i connect the positive to pos terminal on the battery and the negative to negative battery terminal or does the negative go on the shunt?
All i want to do is keep the battery topped up. (i'm pulling the fuses for the radio to get rid of the draw).
do i need to get anything else for (what i'm assuming is a pretty basic set up). Next season will be getting into lithium batteries.
thanks!
chris
thanks!
chris
