solarHandyman
- Jul 22, 2020
- 55
For reference: https://www.amazon.com/Li-ion-Lifep...ds=16s+battery+balancer&qid=1614110048&sr=8-4
Hi, I have 4 pairs of the infamous BYD 24v batteries (Tech Direct, BatteryHookup, BatteryClearingHouse), wired in pairs for 48V. To manager the entire group of 16 cells, when connecting this simple battery balance board (not a BMS) the board starts smoking and it looks like it wanted to catch fire (can't learn anything without a couple dead shorts catching fire I pulled the plug before that happened. I only tried connecting one. Same result 12 hours later after calling it a night....
My batteries are not exactly top balanced. I just got a little bench top variable power supply tester off Amazon which only does 300 watts max to get them up from below 25 volts as they were when purchased at Battery Clearing House in Raleigh.
Is my issue that my difference in voltages between the two 8s packs are just too great for the board and its little chips to handle? If I could get all my packs within 0.5 volts, would this little board work out for me?
I didn't want to go with a $100 BMS because low temperature/high temperature cut offs and low voltage disconnects are not an issue for my installation.
Any help would be appreciated comrades
