I have four 100 W panels to be mounted on my RV. Because of the layout of the air conditioner one will likely most always be somewhat shaded. As a result I had planned to hook up the panels in parallel.
Open circuit is 22.3 VDC and 5.86A per panel. So that leaves me at 23.4A.
I was considering a Bluetti AC200max But now I see that its incoming PV current is limited to 15 A.
So is there any reasonable way to step up the voltage and step down the current of my PV output before it reaches the Bluetti?
