Wazersdea
- Sep 25, 2022
- 13
Hello Guys!
I'm planning to purchase a 5kVA 3-phase transformer with voltage 380V to 220/200V for my laser cutting and plastic molding machines. The features I'm looking for are as follows:
1. 3-phase autotransformer should have enough power, the wiring should be tight and neat, and does not skip turns. Coils adopt insulated H-class enameled wire, with low no-load current and low loss.
2. The 5 kVA dry-type autotransformer must be built-in silicon steel sheet with good magnetic flux performance, high heat dissipation coefficient and low magnetic loss.
3. The autotransformer must use electrophoresis technology clamps, no burrs on the edges, rounded corners to prevent collisions, and not easy to corrode. Tinned copper tube terminals and rail-type wiring ports are convenient for wiring and ensure that the power-on overload capacity is increased to the extreme.
Can you pls suggest me some more about it and is it good for laser cutting and plastic molding machines? Looking for recommendations.
Thank you!
Thank you!
