My SCC's are EpEver clones sold under the rebranded name of "ACOPOWER MY40 Midas Y Series, MPPT Solar Charge Controller." They are 40amp 12v/24v auto detect. I am using them for a 24vdc battery bank, see below for configuration.
The SCC's have various settings for charge rates at various levels of discharge. The manual for the SCC has parameters for each of these levels. See Attachment.
They use the terms BOOST, FLOAT. and EQUALIZE. When looking on the web, there are other terms such at BULK.
Questions:
** In the attached chart there are values for each of the settings.
**** Are the numbers correct?
**** Do the numbers represent the level where the settings kicks in, or where it shuts down to lesser current?
**** What is meant by BOOST, FLOAT, and EQUALIZE, and how do they relate to BULK?
**** Should I set the charging parameters using the "USER" section to change parameters to custom levels?
The batteries in the battery bank are Sealed Lead Acid Maintenance Free 100Ah batteries. There are 8 of them wired 2s4p for 24volts.
The reason for asking is that on full sunny days at SOLAR NOON I expect the solar charge current to be running full throttle when the battery voltage is 25.0v. The most I have ever seen for charge current at each SCC at the same time is about 22amps each... which is 1650watts. But at ~27V one or more of the SCC's will drop to between 200ma to 5amps and stay there. The Victron Smart Shunt then shows pretty much a trickle charge (0.85-1.50amps) even though it shows that the batteries are only at 93%. Something is amiss.
Thanks ahead of time for whoever can shed a little light on this stuff. I pretty much understand the electronics part but I do not know/understand the language of battery charging.
Ken
Solar Electricity Investment.
** 1840 watts of Solar panels = (2 sets) of 6 panels/100w each, wired 3s2p. (1 set) of 2 panels/320w each, wired 2p.
** (3) 100/40 MPPT charge controllers
** (8) 100Ah Sealed Lead acid batteries, wired together as 2s4p, 24volt system
** (1) 4000 Watt Pure Sinewave Inverter
** (1) Victron SmartShunt for monitoring Battery status
** (1) 10-circuit manual transfer switch. Connects the solar through an RV 30amp inlet box to the load center. 120v only with solar.
Most of the day the items in the house consume between 500-800 watts. Microwave and coffee pot add another 1500-1800 each for the time that they are used. Oregon is NOT known for its sunshine, so, solar energy must be monitored.
Questions:
Ken
