invento123
- Mar 30, 2021
- 24
So I know CHARGING a LiFePO4 battery at near freezing (40°F) to freezing is a very bad thing and should never be done. However is DISCHARGING a LiFePO4 battery at near freezing (40°F) to freezing bad for them? How about storing them at 40°F or below?
To add on, the batteries in question are 2 100AH LFP batteries out in my shed running some lights and such that I usually only pull around 6 amps out of them, will even this small load damage the batteries if it is say 40°F or below outside?
Final question, I have a 80 watt solar panel mounted on the shed that, in peak daylight really only puts out around 60 watts/4 amps, this means each 100AH battery is only charging at about 2 amps. Again in 40°F or below temperatures, is even this extremely low charge rate bad for the batteries and does it have the possibility to damage them?
Thanks in advance!
Thanks in advance!
