once111
- Aug 25, 2020
- 2
Equipment:
8 x new Fortune 100Ah - 8p0s configuration
Kaiweets PS-3010F - 10a/30v variable power supply
BMS - None at the moment, overkill BMS going on after top balance and final cell config (0p8s)
I know some of what I am doing is not necessary with new matched cells. I also understand that some of this requires a lot of attention without certain safety measures like using a BMS. I am trying to use this opportunity to experiment and learn about these techniques I am studying before I have to put these batteries into production. I am trying to manually top balance my cells after a manual bottom balance. I have all the cells in parallel, so I have currently configured a 3.65v 800Ah battery.
From my understanding, the primary points of charging LiFePO batteries are to charge at Constant Current (CC) until the cells reach absorption at 3.65v (~90% SOC), then switch to charging at Constant Voltage (CV) until the current reduces to almost nothing (~100% SOC). The Kaiweets PS supply does 10a, so I was hoping to use the full 10a for the CC phase, as this will only be a 0.0125 C rate and slow enough at that rate. As I understand, this low C rate should not affect the charging other than taking a long time, 80 hours from zero to full. When I started my charging, I saw numbers I don't like and wanted to see if I have an issue with my understanding, technique, or equipment.
To start all cells were connected in parallel and allowed to equalize. The entire bank was 3.072v and all cells were within .001v. I configured the PS for CC at 10a, but the voltage of the PS rose to 3.94v instantly. After running a few minutes, I reconfigured and tried a 5a CC setup and the only came to 3.50v. While the 5a config looked like what I was expecting, the 0.00625 C rate is really low. I did not let either config run for more than a few minutes, hoping to get some clarification before doing anything that might hurt the cells. After these attempts, the bank is reading ~3.08v and all cells all show the same voltage.
These cells in parallel are capable of 800a at a 1 C rate. The suggested charge is a .5 C rate, or 400a. I am so far under these rates I don't understand the high voltage I am seeing. Looking at cell/bank voltages, not under load after a decent rest period, my ~3.08v cells are approximately 10% SOC. This leads me to assume the internal resistance of the cells is still on the low side, therefore it shouldn't take such a high voltage to push 10a. With that jump from 5a/3.50v to 10a/3.94v it would seem that moving to 20a+ chargers would run a crazy high voltage.
I feel like there is something I am missing. Will running the charger at 10a CC result in the voltage eventually dropping from 3.94 to the 3.65 target I am expecting? Is this technique wrong or only works with 5a CC? Do I need to run a base charge of CV @ 3.5v, then run CC @ 3.65, and end with CV @ 3.65? Is my 8p config giving me issues? My PS should be able to handle 8p0s (3.65v), 2p4s (14.6v), or 0p8s (29.2v) battery cell configurations, but I assumed 8p 3.65v would be simpler to start. Not sure what I am missing, and I don't want to overcharge by accident. Thanks in advance for any help.
