Wow, thanks for the comprehensive answer! In my case it seems that the display on my inverter (which is also my SCC) is reading higher than what is happening at my battery. E.g. my inverter was reading 52.9V which correlates to about 70ish%, but my battery was reading 52.6V, which is more like 50%! Due to this, I think that the battery isn't even fully charging because the inverter thinks it's charged but it's not.49.4V = 3.08 Volts per cell in a standard 16S Build. This is the Bottom of the Working Voltage Range (3.000-3.400). If 1 cell happened to go below LVD (Low Volt Disconnect) setting which from what you describe seems to be 3.000. that would cause an LVD.
You stated you do not have a SmartBMS, sorry to say but that was a Mistake, especially for a DIY Battery Pack, you do need the ability to view the status of what the cells are doing and to be able to set parameters for your use case.
While the normal Working Voltage Range is just 0.400 it is very narrow BUT the cells can and should be allowed to drop to 2.700Vpc with a cutoff / Shutdown @ 2.600 Vpc. This is for surge handling that creates a sag... IE when a fridge starts it's surge will pull the voltage down for a few seconds and if that trips over the LVD line the BMS will shutdown. Most Smart BMS' can be programmed for a Delay to prevent a surge from triggering an LVD state.
The ability to monitor the cells also will help resolve issues if something is wrong with the cells because you see the voltage of each cell for troubleshooting. If you have a loose connection or a weak cell etc you can identify it and check it out.
Your operating Range is 48.0V-54.4 (working voltage range)
EndAmps/Tailcurrent for charging is 14A which is the point that Absorb switches to Float to finish off the battery pack to 100%.
Suggested BMS Settings for a Smart BMS: (most have similar programmable settings)
Cell Overvolt Protection 3.600
Cell Overvolt Release 3.500
Cell Undervolt Protection 2.700
Cell Undervolt Release 2.750
Power Off @ 2.600 (never get to 2.500, and this allows a simple restart)
* Charge Over Current Protection Delay (time in seconds) 30
* Charge Over Current Protection Release (time in seconds) 60
* Discharge Over Current Protection Delay (time in seconds) 200 (to allow for a device surge that causes a sag that drops below LVD setting)
* Discharge Over Current Protection Release (time in seconds) 60
THERE IS A NASTY GOTCHA LURKING HERE TOO !
Voltage Drop between Actual Battery & Inverter/Charger & SCC (if separate).
There is ALWAYS a voltage drop due to the wires, lugs/terminals, switches, fuses & breakers "Ces't la vie".
Once fully charged take a GOOD DMM/DVOM and measure the Actual Voltage @ the Battery Terminals, the SCC, the Inverter/Charger. The "Battery Rules" not the other devices !
EXAMPLE: IF the Battery terminals are @ 54.4 and you see the Inverter terminals showing 54.0 +/- the SCC may show 54.6 +/-. That differential has to be addressed so you correct & compensate for that in your Device Settings. If you want the Inverter to cutoff @ 44.8, then to should be 44.8 @ the battery as well, if NOT Corrected it will cutoff @ 45.2. Similar applies to the SCC for Charging, if you want it to charge to 54.4 @ Battery then you have to set that correction (IF it does not have a Voltage Compensation setting, Most Tier-1 SCC's do have that facility) then you do it in the charging settings by reducing the charge voltage by 0.2.
* A Typically an SCC will see higher voltages as it is the incoming source prior to derating & loss.
* An Inverter will see a lower voltage as it IS derated from batt to inverter.
A Good SmartBMS with Active Balancing (2A or 3A for a 280AH Pack) General rule is 1A Balance power per 100AH is the best solution. I would highly recommend a JKBMS B2A20S20P with 2A Active Balancing, 200A Capacity, Bluetooth & RS485 with the extra Add-on LCD Screen with power switch. NB: the BMS itself ships with an On/Off Switch but the wire is only 5" long.
One vendor for example:
45.94US $ 29% OFF|Jk Bms 1a 2a 5a Balance Current 8s 12s 13s 14s 16s 17s 20s 24s Smart Jk Bms 60a 80a 100a 150a 200a 600a Lifepo4 Li-ion Battery - Battery Accessories & Charger Accessories - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
If I were to install a smart BMS with active balancing, would that negate the requirement for me to top balance?
