I have a 120ah lithium battery with a 100/20 Victron solar controller and 250w solar panel, the battery is a commecially bought drop in
The victron will sometimes report a low voltage overnight of 11 volts or so, most times it says 13.16
I have a seperate battery monitor that shows the battery over 13 volts overnight, this one logs a reading every 2 minutes while the victron only gives the highest and lowest values
When I first got this battery it would randomly cut out for a second, the fridge and radio would turn off, at that time I had an epever controller and apparently they can do strange things with lithium batteries so I changed it to the victron
Since having the victron I've had no more battery cutting out but I am seeing these strange voltage readings
The battery is running a 38 litre Engel as a fridge and a 45 litre Oztrail as a freezer overnight and seems to be working fine, it gets down to 92-94% most mornings and is usually fully charged by midday
I'm wondering if there is some wierd switching thing with the victron mppt doing this or if it is a fault with the battery, bearing in mind the other battery monitor shows perfect readings
It has me stumped, Anyone like to offer any advice with this, I'm happy to supply the spreadsheet readings from both devices if that would be useful
