Joshbal12
- Dec 9, 2021
- 1
Hello from the UK!
Sorry I've done as much research as I can on this without seeking advice:
I've obtained an working scrap 250w panel with the below specs. I've got a 12v battery as bellow and I've been trying to thing of the most efficient and cheapest way of connecting the 2.
As far as I've read I think my kind of panel is unfortunately the type to be directly connected to a grid rather than dc 12v or 24v batteries?
In sunlight, straight across the panel I get about 32V with a multimeter.
I'm unsure whether to step down the panel voltage (with a cheap buck) and increase the amps, then feed into a cheap PWM charge controller which then goes to the battery.
I've also considered this to step it down before going into the PWM :
Or if I should by the cheapest (real) suitable MPPT controller to sort the charging for me.
I'm really on a tight budget so reluctant to spend the £60 + for an MPPT unless it's necessary.
Can anyone recommend a real cheap MPPT for the UK?
Please let me know if I'm being completely ignorant with my set up ideas! I'm still very new to this!
28.32US $ 42% OFF|300/400W MPPT Step down Real time Tracking Solar Battery Recharging Controller LED Display 10~30V Output Voltage Adjustable|Solar Controllers| - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
a.aliexpress.com
