fish1534
I've been getting quotes on solar systems and am struggling between an AC and DC coupled system. I've been reading through many threads and it appears most people prefer DC coupled but I think that depends on your situation. I live in FL and we have net metering, my goal is making money, the highest ROI. My situation is:
I have a two story roof over my house and a single story over the garage.
Both roofs face east/west with no southern exposure.
I have trees that will create shadows when the sun is at low angles but I'm clear directly overhead.
The power meter is over the house, and the electric panel is on the opposite side of the house in the garage.
I'm looking for a 25-30 kW system so my yearly Net metering is 0.
I can fit about 60 panels on the main house roof.
Main usage is to run three air conditions in the FL heat.
I do not care about being grid independent.
My thought is to put up an AC system on the main roof that feeds into the panel to achieve NET 0. FPL only has two rates, you purchase at the retail rate and sell at the wholesale rate. I don't think it's worth producing extra power and selling it back at the wholesale rate. Extra capacity to sell at the wholesale rate would just lower my ROI and I would be better invested elsewhere. I don't see any reason to invest in batteries when I am effectively using the grid as my battery. I don't need the grid when the sun is out and when it isn't shinning the grid is my battery. All this points to AC. The microinverters will handle shading better, it's easier to connect these panels at the meter instead of the electric panel, and for efficiency I only have one conversion to AC.
The wrinkle is I may want to get an EV so i stop paying for gasoline and double down on my solar investment. I'm concerned about ROI and it seems that we will all drive an EV eventually. I guess it also wouldn't be bad to have the capability to power the house from the car battery at night or if the grid goes down but this is not the primary concern. I've been through plenty of hurricanes and lack of power has never been an issue. I also worry that batteries will improve greatly in the coming years and any DC batteries purchased now will be the equivalent of a 1970s $30,000 microwave. I could also install 10-15 kW of panels over the garage when I buy an EV and have a split system. This would also be an easy wiring job to the electric panel.
Questions:
Which system is better in my situation?
If I go AC am I wasting my money by not future proofing my investment? It appears this group prefers DC.
Why do people install their own batteries instead of use the grid as a battery.
Do I really need micro inverters to handle the possible shading?
Is it dumb to have an AC and DC system? Can these be made to work together or is that needless complication? Will the wiring two systems be more complicated with each system at opposite ends of the home?
Could I power the home from the EV or future DC batteries?
Am I missing any important factor?
Questions:
