Hello, Wiring a subpanel in my RV, 110 volt single phase, subpanel powered by the "output" of a 2000watt inverter(with transfer switch built in). Moved 3 breakers from main panel to a subpanel, which powers the 110 volt AC plugs in the RV. Standard wiring: 3 Neutral white wires to isolated(floating) neutral bar,3 green to ground bar connect to metal subpanel housing, and black hot to breakers. Then I used a 10GA green wire to connect the ground bar of the subpanel to the ground bar of the main panel. Using a 10GA white wire I connected the floating neutral of the subpanel to the floating neutral of the main panel. I talk with two different inverter tech-supports persons, who told me to disconnect the neutrals form the subpanel to the main panel are it would cause damage to the inverter. Can anyone tell me why the neutrals should not be connected? I know there should be only one neutral to ground bonding which only happen when you plug into 110 volts shore power.
