Hello Thanks in advance.
Im a newbie who just installed my system with 15s 1p 302Ah Chinese so-called catl cells, 300A jbd bms, growatt 8000kw dvm mpv inverter.
I was running my system very well for 1 night for some security lights. Xiaoxiang app sad I have reamining capacity close to 300AH
Than next morning as soon as I get up around 6am, all the light turned off. The inverter went off. I checked Xiaoxiang, my cells were undervoltage, especially 1 was the worst at around 2.4. and the remaining capacity has dropped to 0 from about 300Ah. I cant understand how this can happen.
I am not sure if my cells are balanced because the cheap dc power supply smoked out when I attempted it. And when I saw Xiaoxiang app, it says the voltage difference is very low at around 3.31v. So I assumed it is balanced and skip that step.
I am wondering is this a coincidence or not that this happend around when sun comes out. I live in desert and sun is very strong.
Inverter showed undervoltage fault and right now I can't turn it on...
Please give me an advice...
This is the graph i see. Is it really possible remaining capacity suddenly just drop to 0? Or it is some problem of bms??
