suggest some >10 kW AiO
DerleT
Croatia
I have EASUN SMP 5k, worked great for over 4 years, now I need more power, so let me know any suggestion for over 10 kW, closer to 15 kW or more that I can buy in Croatia.
Single unit or 2-3 in parallel will work, 48 V system, 230 V, 50 Hz, single phase, grid tie...
any experience with buying SRNE inverters? where to buy, who to contact and other tips...
is it easy to add them to Home Assistant?
anyone else with any other suggestions?
Borick Solar (https://www.boricksolar.com/) is where @42OhmsPA and I got ours. I think a few others as well.
I don't have the dashboards very well built, but, yes, it's doable in HA. You can change settings there too. Although, I am pulling this data via MQTT from Solar Assistant, which I'd recommend having as well.
Awesome suggestions!!! Keep them coming!
I really like Sunsynk 16 kW, you can connect two batteries, it has 3x MPPT and you can connect two strings to each MPPT.
The Deyes are nice since they 2 battery ports and 3 MPPTs.
You can connect more than one battery and string to other units as well, even if they don't have the ports...
Using my ASPs for example.
I currently have 4 battery banks that connect to buss bars, from there I have a main feed to the inverter. I'll be adding more battery banks in the near future, buss bars make that really easy.
My MPPTs are rated for 22A so I have parallel strings of panels running to them from a combiner.
I now have two batteries connected via buss bar to inverter, but it look like a good solution to have dual connections on inverter that can take 300 A.
