suggested wire gauge?
jeff
What is the suggested wire gauge necessary for 4 HQST 100 watt 12 volt polycrystalline solar panels with a run of 50feet?
... starting with only two, and 24volt, if I can do it. ...and a EPEver 40 charge controller, I hope!
50' roundtrip or straight distance?
200 watts @ 24 volts means 8.3 amps.
Will you be expanding ever?
Run wire that will accommodate your eventual usage vs running wire several times, copper is not cheap.
Thanks for the reply's! ...and the info!!!
Sorry it took me so long. just a bit embarrassed.
