Hi, I'm building my own system from scratch and currently have 8x Trina 295w solar panels sitting in the garage.
The specs are Vmp=32.5v, Imp=9.08A, Voc=39.6v, Isc=9.68A, Max fuse=20A.
I was looking at getting 2x Ecoworthy 1kw units (22-65v) and attach 3 panels in parallel to each of the two phases.
However decided I need something larger and future proof like a 3kw inverter on each phase along with a battery backup capable in the future.
So I figured the Growatt at https://watts247.com/product/2-x-spf-3000tl-lvm-48p/ would be ideal.
I'm just not sure if I would be able to somehow attach a limiter clamp in the breaker panel with this inverter. Reached out to Ian and he replied "These inverters do not backfeed. So no worries". I replied saying how does the inverter know not to push excess amps out to the meter and he said "This is internal, you can either enable or disable grid feedback. Your meter will not spin backwards, ever, not designed to do that. The worst that can happen is to stop it". My understanding of the limiting function is there needs to be a clamp that goes around the hot lead in the breaker box to measure the current flowing in. Am I missing something?
