TimC
WI/UP Border
- Apr 17, 2020
- 139
I want to have a solar system to back up electric power during very infrequent outages (two short outages in five years). I'd like to power my fridge and freezer full time, which are rated less than 3 KWh/day combined and have enough reserve storage for very conservative power usage if the grid goes down. I'm shooting for three days of storage for the fridge, the freezer, a minimum number of LED lights and in winter my furnace (900w peak and 600w continuous when running.) I no longer have actual per day consumption of the furnace. An educated guess would be the furnace runs for two to three hours per day Dec thru Feb. I have a Kil-o-watt meter that I can plug the furnace into, but, being fall and currently 70 degrees I don't see getting actual consumption numbers right now.
Here's where I am for equipment... I have two 100w Renogy panels (12v) and one Epever 30a charge controller. I do not yet have a battery bank for use in this effort. I'll likely chose AGM batteries as I have had excellent service life with them in the past when kept at full charge. I agree that in the long term some sort of LI-Ion battery may be more cost effective, but, I am trying to build a more reasonably priced system right now.
I am not saying I need to use the two Renogy panels, I realize the 300+ watt panels available are probably more efficient and will build the system around just the Epever if needed. I am not sure how the higher voltage panels work with a battery bank. I believe the Epever is good to 24v.
So, using the Epever and knowing I'll need batteries, a very clean inverter and solar panels where should I start calculating the size of the system? If you could advise in layman's terms please. I am familiar with solar for my 12v camper (the source for the charge controller and panels) but the higher voltage systems are beyond my expertise.
Thanks
Tim
Thanks
Tim
