I recently replaced the house bank with 2 100ah LiTime mini units. I have a 2 outboard setup with 2 Blue Seas ACR, one for each engine. I also have 200w solar with a Victron MPPT 75/15 controller. There is also a Prosine 2.0 inverter/charger. I have removed the house bank from the ACR's, installed a DC_DC charger and fed it from one of the 2 AGM start batteries. The solar is now charging the house bank only. The Prosine algorithm has been adjusted. My conundrum is off season. I live in Maine so winters are harsh. I plan on removing the house bank and storing them. I have always left the AGMs and the solar kept them charged even through the shrink wrap. So my question is can I use a solid state relay controlled by a switch labelled summer/winter the result of which would allow both AGM start batteries to be solar charged during the winter and in the season would revert to original configuration. Is voltage drop an issue if using solid state?
