Sun rises - newer energy (SRNE HEBP series)
Isn't the only spec difference (HEBP vs HESP) the 200A max & 90A max grid/generator current handling ability respectively? The rest is the same. as far as I see. Or am I missing something?
Much larger MPPTs as well - able to handle 18kw of PV versus the previous limit of 13,000
Are there more in depth surge ratings specified somewhere? All I see is the 1.5x power (no time period) in the datasheet.
For the HEBP series inverter?
For the ASP's, I did 2 load testing videos that are in my build thread. A few things I found, when using a grid parallel connection, PV power is used to run the loads first and it is supplemented by grid power. Excess PV is used to charge the battery. Battery power can be set to have priority over using grid power with the time of use settings.
That is probably why you won't see a time period in the spec sheet. Running off pure battery power, I loaded the pair and a single down heavily and the inverters just ran out of inverter capacity when on just PV and battery power. I never had a shutdown when overloading the inverter but a high inductive load would not start or start completely when overloading the inverters.
The HEBP is a hybrid and will run parallel to grid. I would not worry about the surge rating in some respects as the unit will pull from grid what it needs to start a load. On the ASP, that function was seamless, a heavy inductive load with inverter in parallel was easily started.
Videos for load testing are in my shop build thread.
Except when the grid is down. Then it has to handle the start surge all on its own.
It is fair to ask how well it does that so you don't overload it during grid down situations.
Mike C.
No different than any other hybrid out there. What is your point? It is rated for 1.5 times the output.
If you want to know for how long, buy one and test it before the grid goes down and then you will have the answer. I test my inverters after install, then I know for certain what will run and what won't. I don't trust the "lab results" you referred to in another thread about a certain brand of inverter. I rely on real world tests and the intended application. Many variables including wire length, wire size, the number of connections and even the busbar ratings will have an effect.
The surge rating of an inverter is what it can do grid down.
If it isn't good enough for your loads, when they start grid down, the inverter will trip and you have no power to anything. The ways to deal with that are to have enough surge capacity, to install soft starts, to put hard starting loads on a panel not backed up by the inverter, or to have some sort of grid down interlock to load shed.
Every hybrid inverter can deal with surge grid up since the grid handles it.
Mike C.
Nothing new there, it also is the rating it can do without any grid connection. Which is how I roll......
You covered some of it but you missed the easiest one, add more inverter power.......
Don't rely on lab test results, always test first in the real world environment like I described.
Mike C.
"No different than any other hybrid out there."
What happens with the PV over 12kw? Can it be used to charge a battery, export to the grid or is it just wasted?
This is a great question Sir - I do not have the answer. For me it would be awesome if the excess could run loads and charge batteries (I don't need grid feedback)
Looking for your HEBP. I have HESP and it runs very well. The only complaint I have is that the LED is flickering when running off-grid (isolated from grid power).
Nice! How long have you had your HESP up and running? Do any load testing?
The LED lights in your house?
What's your N/G bond situation running off grid?
All LED or one? Could be a crappy bulb.
Few cheap LED, but when AC with soft start initiated, all LEDs are flickering for 1 second.
Also, is it possible there is another bond somewhere after the AIO?
Not from sub panels and main panels, do you know how we can check without open all outlets and switches? I will check all smart switches since I saw many people put PE-N together.
not really related buy my anker 3800 caused on set of LED lights to flicker on one of my ceiling fans. not sure why.
You could check continuity but you'll have to disconnect all loads / connections then meter between N/G.
I'm not an expert on that part and could be wrong, someone please correct me and/or elaborate.
