Horsefly
Solar Wizard
SFK has posted their own video now. I don't think they mention @RayfromTX but they try and make some bogus claims:Why would SFK not test the cells themselves with the same tester that most of us have, BEFORE sending them to Ray????? Seems like common sense. I've tested cells from Sanben and Liitokala that were under capacity 5-15aH. Then all from Amy-Luyuan and Hayley-Dongguan Lightning met or exceeded cap. It's not rocket science when you test them all the same exact way. If all of Ray's or my own cell testing from various suppliers showed 275-277aH, then we would be the ones with calibration/testing issues.
- He claims that the Ah measurements from the EBC-A40L is not accurate because there is some loss in the alligator clips. Wrong. The current is the current. All of the current is going through the entire circuit, even if there is some heat loss in the wire or the clips. There are watts lost because there is a voltage drop, but the current is the current. Basic circuit theory, and he doesn't seem to get that.
- He tries to say that what matters is the Wh, and then he gets to whatever Ah he wants by dividing the Wh by whatever voltage he wants. The reason we measure capacity in Ah is because the voltage changes during the entire discharge. Ah is the only way to get a repeatable comparison between cells. Again, basic.
