zanydroid
Solar Wizard
Do you plan on having separate batteries and solar panels as well?I see no issues feeding separate panels from each split phase version, this would also give you redundancy if one were to have issues.
One big ass battery bank feeding the inverters from a main buss, multiple arrays to the MPPTs.Do you plan on having separate batteries and solar panels as well?
Your theory is exactly what I’m doing.I'm shopping for inverters and so far this SRNE 10KW is at the top of my list.
What is the best way to obtain this unit?
Via Sungold, PowMR or direct? I really don't care about the color or cosmetics.
Its crazy that this unit is 10KW for about $1500 while the Lux Power unit is going for about 4x the price.
I don't believe these units can be paralleled, right? Is there any talk of that? Or has anyone noticed anything in the connections or software that indicate that might be possible in the future?
If they can't be paralleled, then I will likely obtain one of these, and power it from a breaker off my existing 200 amp main panel and power a subpanel with the inverter. Then move circuits from my main panel to the subpanel as my installation progresses.
Then at some point, probably add a second inverter and a second subpanel and continue to do the same thing. The loads I want to keep on the grid, like the shop air compressor, machines and welder would stay on the grid. I don't want to have my welder trip out an inverter and shutdown my house power. (The wife would be annoyed!)
Does anyone see a problem with this concept?
It makes very little sense to do these projects to “save money on electric” and have a 20k+ device install overhead, sure you can pay it off over time, but I work in IT and I learned long ago it’s not wise to finance IT over extended time periods,
Both are UL1741. But for roughly $150 more, the SRNE delivers 10KW vs the 6KW of the Luxpower. That's a big difference!
The SRNE can deliver 66% more continuous power than the Luxpower 6K, so it is an apples vs oranges comparison?
Its probably better to compare the Luxpower 12K to the SRNE 10K. I can install 2 - SRNE 10K units for about $1600 x 2 = $3200 whereas 2 - Luxpower 12K units would be $5200 x 2 = $10,400.
That is a crazy price difference. I could buy 6 - SRNE units for less than the price of 2 Luxpower 12K / EG4 18KPV units.
I'm not totally sold on the idea of paralleling units to get more capacity. From a reliability standpoint, if I do something dumb and destroy something and the inverters are in parallel, its possible I am going to destroy two inverters at the same time. If they are separate, that's a lot harder to do. I've been involved in controls and drive technology for a long time. I have seen situations that have destroyed hundreds of thousands of dollars worth of high end controls and drives. Lightning, contaminates, wiring mistakes, etc. Stuff happens.
Mistakes happen. I'd much rather pop a $1600 unit rather than a $5200 unit.
Another difference might be AFCI and ground fault protection which is required on a structure. AFCI really sucks to retrofit.
There’s a lot of 1741 stuff with MPPT that do not have AFCI. The direct solar powered Deye heat pumps being one. It is allowed presumably because there are legit scenarios where you don’t need it.
AFCI is a widely ignored thing in the midwest USA.
Hello how did you connect the powmr input . I am getting one as well 10k but out puts are going in a sub panel so I can put my centra ac pool pump ect any suggestions will be appreciated. Or help with set up too. So far I have 2500 watts solar panels..Yes, that's the one. I have the PowMr version of it. Works flawlessly so far. Just the data coming from it is rubbish. Tells you it has discharged 200Ah from the fully charged battery and then has charged it with 290Ah. It's off by approx. 90Ah within 24 hours. I am in contact with SRNE because of this. Also it cannot calculate the SOC of a battery bank, that has no communication, because there is no parameter to set the size of the battery, so you will need an external shunt, like the victron shunt, if you want to know the SOC of your battery. There are other data flaws as well, but elsewise the machine works well.
See the replies from @Kenny_ and myself in the other thread you are posting in.Hello how did you connect the powmr input . I am getting one as well 10k but out puts are going in a sub panel so I can put my centra ac pool pump ect any suggestions will be appreciated. Or help with set up too. So far I have 2500 watts solar panels..
Hello! That is nice I did the same canopy but is not attached to the house is out by the pool area so is on 4x4 post and 2x3. Looks great any input on your inverter connection and sub panel thank you.Got a lot of stuff done today. Had most of the house on solar in the afternoon (no hotwater, no garage refrigerator, no mini splits) Everything doing well with the unit. Researching batteries now.
Pics:
Hi Schamp what is the model number on your PowMr I got the sungold but not sure on the PowMr trying to decide wich unit to buy thanksYes, that's the one. I have the PowMr version of it. Works flawlessly so far. Just the data coming from it is rubbish. Tells you it has discharged 200Ah from the fully charged battery and then has charged it with 290Ah. It's off by approx. 90Ah within 24 hours. I am in contact with SRNE because of this. Also it cannot calculate the SOC of a battery bank, that has no communication, because there is no parameter to set the size of the battery, so you will need an external shunt, like the victron shunt, if you want to know the SOC of your battery. There are other data flaws as well, but elsewise the machine works well.
It's called Sunsmart-10K split phase inverter. I don't know the exact model number, because I'm not at the house now. I'll only be back there mid December. But as far as I know, there is only that one model.Hi Schamp what is the model number on your PowMr I got the sungold but not sure on the PowMr trying to decide wich unit to buy thanks
Well, my house there is a bit complicated. There are 3 phases 220V/50Hz coming into the house, but the guy that built the house was from the States and he also wanted 110V, so he installed a huge autotransformer (20kW) to get 2 phases of 110V, and those 2 phases L1 +L2 are connected to the inverter mains input. Of course these 2 phases are also 50Hz. I think Curacao is the only place worldwide, where lots of houses still have 110V/50Hz coming into the house, but mine only had 220V, so that's why he needed that transformer.Hello how did you connect the powmr input . I am getting one as well 10k but out puts are going in a sub panel so I can put my centra ac pool pump ect any suggestions will be appreciated. Or help with set up too. So far I have 2500 watts solar panels..
Looks like a pi computer with a sungold label stuck on it.In the picture above with the unit that has a screen that is mounted to the front of a box; What is that ??
Thanks!
Great idea. I agree 100%. Get it going! You’ll be impressed with how much you actually produce. I’m still ‘shocked’ how well this works and how much power I am producing during the day.My feelings exactly. If I pay it off in 20 years, then what is the point? Stick the money in a few stock market index funds and you would be further ahead. A 7.2% return for 10 years is a 100% return on investment (Rule of 72) .
My plan is to go with used solar panels. I can get them, within driving distance, for about $1100/6KW. I want to mount them on a welded steel frame, tipping ground mount rack of my own design that is generic so different sizes of panels can fit on it in case I want to swap them out. My current idea is to make the angle facing south adjustable via lift cables and a hand winch (think boat trailer winch). Loosen the rear mount bolts and raise/lower the north side of the frame via a crank. Retighten the mount bolts and I am good for another two months or more. I have a surplus steel sales yard about 10 miles from my house so obtaining relatively cheap steel is not difficult.
It’s an orange pi with Sa running on it. I didn’t want to see orange. I want blue dammit! Lmao yeah it’s a stickerIn the picture above with the unit that has a screen that is mounted to the front of a box; What is that ??
Thanks!
