jbatx
I make stuff with things
Hey all, I didn't find much on Sungold's twist to a 6kw split phase hybrid system. It delivers 6kw split phase 240 from its two 3kw 120v lines. It uses the SolarApp and SaaS platform that others use. ...I imagine that the mfg provides the platform for their customers.
The unit: https://sungoldpower.com/products/6000w-48v-hybrid-solar-inverter-split-phase-120-240vac
...note, that's not an affiliate link. Don't ban me.
I took a chance and bought one to replace my 3kw dumb inverter and Renogy Rover 100a 48v scc. It's now set up with 5kw array, 21.1kw at 48v in lifepo4 and a 9kw harbor freight gasoline generator requiring manual start. Soon, the gene will auto start/stop.
Anyhow.... here's a short review of my experiences with the device and also the support I've received from Sungold
1. It took nearly two months to get the device after direct ordering it from their site. This was not disclosed when I ordered it and I was pretty I unhappy about that. However, the communication from them was very good. They responded within 24 hours to every email I sent. I received the unit about 2 weeks ago.
2. It was packed very well with Styrofoam forms and thin plywood. It weigh about 75lbs or so.
3. Set up was simple and will be easy for an experienced solar hacker type. It's got a lot of settings and options that would make it a challenge for a beginner. I knew what I needed my bulk, float, etc setting to be already.
4. The UI menus are impossible to interpret unless you read the manual. I read it multiple time and now navigating the menus on fhe display is a breeze.
5. Out of the box settings were reasonable and pretty safe. It auto detected the voltage but I did manually set the battery as usr defined, change the bulk, float, low cutoff, discharge return, etc to more logical values.
6. AC input was set to 60h by default and APL making generator connection easy. My generator is delivering 120v + 120v. The internal transfer switch works well when the generator starts and stops. The unit switches between pv and ac on its own and the default settings worked fine.
7. The absolute charge current is configurable from 10-120a. You can also set how much AC charge current should contribute to the total. For example, I set my total charge to 90a and AC to 90a because when I'm running the generator there is no pv input. Each of my three batteries has a 100a jbd (from overkill) bms so i set the max to 90a. Interestingly, I did try setting both to 120a for a few minutes but the sungold unit threw an over current fault and shut down. I turned it on again and set it back to 90 - no issues at 90.
8. There are some issues that I needed to solve with this unit and so far it has solved them.
A. Easy generator connection
B. Auto start after overload
C. Batteryless operation so i can run on pv or generator when doing battery maintenance or when they're fully discharged. ...it happens in the winter.
D. Remote monitoring and parameter editing.
9. The wifi setup and device registration with the SolarApp was a pain in the butt with a pretty poor ux. It didn't work 4 or 5 times, then it was added twice and no data showed up for about 2 days. Now it's working fine and I have changed parameters remotely.
10. Service after delivery has been great. This includes questions about the SolarApp and support of it. They helped me get it working over email and even sent back screenshots.
11. It's two 3kw 120v lines have no discernable ability to go over 3kw. I tripped it running my 1.8kw induction cooker and the mrcool minisplit on high (1.1kw) and alot of led ights. That was about 3kw on the nose. The auto-restart feature kicked in here, which was nice.
All in all, I'm pretty happy with it.
