I just received this for my offgrid home project
https://www.amazon.com/gp/product/B00S4DZRSK/ref=ask_ql_qh_dp_hza?th=1
24V 6000W inverter charger - $1099 + tax. Very heavy and well built. Initially looked very good, then some problems arose.
Just turning on the unit and having it idle consumes 155W, that's over 3700W or 3.7KW a day. Thats a whole bank of batteries needed just to turn it on and you will need a big solar array to replace that energy. If you run anything fridge / tv/ lights etc, that's in addition to this load, so if you want to run a 100W light, you will be using 255W. The only idle consumption usage numbers mentioned in the manual and sales literature is 25W. They covered the real consumption numbers up. Turns out the low rate documented is in idle/standby mode which has its own problems, making it unusable
I wanted this split phase unit to run my house off-grid 24x7, I don't want to have to turn it on and off each time I want electricity, but having an inverter use nearly 4KW a day just to idle is crazy, that's nearly the same power I use myself to run the house.
I tried Power Saver mode and that uses a fraction of the power, 25W, that looks promising, but unfortunately it doesn't work. In the standard setting, it's meant to search every 30 seconds for a load on the AC circuit, but it doesn't work. If you switch the toggle #3 on to enable a 3 second search, that does work, but only searches on 1 side of the 240 split phase, plug the same device on the other 120v leg and it doesn't work. Why? Was this a cost saving measure?
So, initially this device look great, but it consumes so much power, its not worth it, especially when its power saving feature is broken.
So you will need
four 12v 100a/h batteries ($200 each) and ten 100 watt solar panels ($1000) just to run the inverter itself. Forget plugging anything into it. I tested its power consumption using 3 different methods and they all concurred. Its that bad.
What alternatives are there for whole house split phase inverters? How much idle power do the MPP units take?
