Ruff Rider
- Dec 26, 2020
- 2
Hi All,
I'm following this forum some time now but this is my first post.
Just installed this residential setup:
48V 16 cell at 272Ah Lishen battery
Daly 16S 250A BMS
16 x 265W solar panels
Sunmart MKS II 5KW B all in one inverter (and a second arriving to go to 10 KW)
Everything is working fine only having some problem with the software that came with the inverter. It came with a soft called WatchPower but this not compatible with the raspberry Pi I would like to use. Is there an alternitive to use?
Secondly it came with a WiFi Plug Pro datalogger witch is using SmartClient app. I was able to install, configure and register this app. I can see my 'powerplant' and the real time data but it's not showing any historical data. Is there someone using this SmartClient app?
Greetz
Ruff
Daly 16S 250A BMS
Greetz
Ruff
