I have a SMA SB6.0-1 SP-US-41 with Tigo TS4-R-F. Installed in 2020 was initially told SPS was not possible due to rapid shutdown requirements. Emailed SMA recently and got this reply.
"You can use the SPS in conjunction with the TS4-R-F, to do this you need to make sure of two things: Inverter needs to be on its latest firmware Inverter needs to be set to "Rapid Shutdown Mode: Sunspec' with "Secure Power Supply On" The SPS will work but only for the rest of the day that is activated, if the outage lasts more than 1 day it will not work for the next day, this is due to the TS4 modules design."
Posting this everywhere relevant because getting this operational is a huge benefit and getting good information on it has been a headache.
