I read the manual today and saw that the DIGIN pin cannot be reassigned to another function on my 6048 Sunny Island. DIGIN is used to signal that the transfer switch is in GEN or GRID position. The two relay outputs can be made to do all sorts of things. Does anyone have any ideas for a way to remotely shutdown the sunny island with a single switch input? I'm thinking of making the BMS trigger the SI to shut down. Another idea I've had is to put some sort of solenoid on the breaker on the face of the unit... a hari-kari solenoid if you will. Suggestions? I'm just brainstorming.
