bruceduncan
- Dec 29, 2019
- 1
I'd be good to go with 60 of them. ??
10,000 might melt something.
If these panels degrade like pretty much any others new at 305w, and ~2% the first year and 0.7% a year thereafter, that means there should be about 280 w(p) now. (Assuming 10 years old)Hi Jason, Cool. I'll stay on this. I liked your discussion on using pipe for bus bars.
These 305W T5s are for sure not the latest and greatest.
I'll readily concede that I'm new to solar and will probably end up with a couple of the dreaded Frankenstein systems. But they will produce and store 10x the power I need and cost me 35% of the cost of buying a "complete system". And I'll learn a helluva lot (hopefully some of it before spending too much). My thinking is you either pay the money, or you do some work. I'll do the work any day.
Aloha
305 | New | |
1 | 98.00% | 298.9 |
2 | 97.31% | 296.8 |
3 | 96.63% | 294.7 |
4 | 95.96% | 292.7 |
5 | 95.28% | 290.6 |
6 | 94.62% | 288.6 |
7 | 93.96% | 286.6 |
8 | 93.30% | 284.6 |
9 | 92.64% | 282.6 |
10 | 92.00% | 280.6 |
11 | 91.35% | 278.6 |
12 | 90.71% | 276.7 |
For scale these 10,000 panels equal 1/3 the output potential, of this one wind turbine!
From Discover on Google https://www.greentechmedia.com/articles/read/worlds-largest-floating-wind-turbine-connected
Also, the company that developed the project, only has a 1.2% stake in it!Interesting to know this. The 10,000 panels are something one of us could practically buy, and split with others. The big wind turbines are usable but it takes a pretty big operation to buy and use one - I see a few in California, but I'm sure the permitting process would take longer than the rest of my life. The relatively low key aspect of solar has a lot to be said for it.
There was an online auction. About 200 lots of I think 20 panels each. Basically 1200 to 1800 per lot in the end.Anyone know what happened with these panels?
Thanks, I bought 30 of them through an auction company, they were stored in Ontario CA. Was hoping to get some more.
Aluminum - Unirac, IronridgeDid you get any mounting equipment with these? Or know where to get any?
You don't mount them, they are Ballast mount. They just lay there on the surface with basically blocks of cement holding them in place.
