Hi all - I have an existing system with 4kw Panels and 3.7kW inverter (UK FITS scheme with good generation tariff) and plan to add 11kw more panels, a Sunsynk 8.8kW Ecco Hybrid inverter and 21hkW of Sunsynk batteries. I've done a ton of research, reading the Sunsynk manual, Knowledge guides, Keith's videos etc but have one critical question I can't find an answer to:
I want to export, but the DNO have set a 5kW limit. From everything I've read you can set the Sunsynk inverter's "Inverter Power Limiter" (in System Mode, System 2 settings), but it seems that limits the entire inverter functionality (effectively turning it in to a 5kW inverter), which defeats the purpose of buying a 8.8kW inverter to handle peak generation of the 11kW of additional panels. Is that the effect of that setting?
Does anyone know if you can set the Sunsynk with a lower export limit (5kW) whilst maintaining all other inverter functions (e.g. solar to load) at the full 8.8kW?
FYI here's my proposed architecture (this is a standard model, taken straight from the Sunsynk manual, and Keith from Sunsynk has done a good video on it - apparently the Sunsynk plays nicely with the 2nd inverter, even taking AC in from it and using it to charge the batteries). Critically, the CT coil is right before the grid, so the inverter clearly knows the export figure - I just can't find a setting to limit it to 5kW...
