thecampulanceman
- Aug 12, 2020
- 11
You've helped me in the past with my questions and I'm hoping I can get some advice on what's happening...
I just swapped from 12v GEL to 12v Lithium batteries in my camper (converted ambulance). I'm using an Epever Tracer AN 100a controller with a custom profile. My Tracer doesn't have a Lithium profile- I originally bought it 2.5yrs ago and it never had Lithium charging designed in.
The batteries I added is (2) 200Ahr Chins. I charged each separately using a standalone 14.6v 15a charger until the charger turned off. Then I installed them in parallel and set the Epever with settings provided by Chins.
I watched the voltage on the MT50 as the solar charged and saw it jump over 14 6v, showed 15v momentarily, then went into Battery OVD. This happened 3x on day 1. Yesterday, day 2, after several hours of solar charging, I watched the voltage climb and the same OVD happened. At that point, I turned on my inverter and the charge voltage then stayed at 14.4v (set point) for the remainder of the day until the sun faded.
I've never had this OVD and I'm admittedly a little lost. I'll paste my controller settings here but there's nothing I see in them that looks incorrect:
Over Volt Disconnect 15v
Charge Limit 14.6v
Over Volt Reconnect 14.2v
Equalize Charge 14.4v (set to 0 mins)
Boost Charge 14.4v
Float Charge 13.8v
Boost Reconnect 13.7v
From watching the MT50, the voltage seems to climb rapidly once it reaches about 14v - it then goes up through to 14.6 in a matter of minutes after taking hours to climb the lower voltages.
Is there anything I have wrong in my charge settings that stands out? Should I have connected the 2 batteries in parallel and charged them before installing? Should I uninstall and do that? I'm floundering as these are my first lithium batteries and I don't feel comfortable with them yet...
Charge Limit 14.6v
Boost Charge 14.4v
Float Charge 13.8v
