Hello everybody,
I just received my 17 cells from DOCAN ( L280K), but I noticed one of them is having a sort kind of strain on the foil of the vent. There’s also a kind of sweet smell coming from that spot, but there are no substance leakeages from the cell. By the way, when i’ve tested them with ebc a40l electronic load, I noticed a similar sweet smell coming out from the rubber/ plastic which is covering the tester clamps. But Even when it’s in stand-by the cell is smelling, sweet smell. Daisy from DOCAN says it’s just due to transportation moisture/humidity and to have no worry, but I think her standard answer and I’m worry about it. By the way, the cells are 274Ah maximum and not 280 as adviced. Does somebodyelse had this issue ? Is this safe to use it under these circumstances?
