Hey lads,
so got a swimming pool kids are loving it, however they spent most of last year coming out looking like smurfs, so late on in the year we purchased an air source heat pump rated at 1.9kwh, (pump is another 400w total 2.3kw) works amazing got pool temperature from 20 degrees to 30degrees running it for 12hours a day. however as you could imagine cost started mounting up rapidly.
I wanna know if its possible to run a very basic system no bells or whistles that just powers the air source heat pump during the sunlight hours, obviously such a system i would want it to run for as long as the sun could power it, however any cost reduction is better than none? would it be possible to perhaps charge up multiple car batteries then discharge them on the air source heat pump over a few hours? can i perhaps just buy multiple solar panels and plug them in direct to the air source heat pump? got over 25sqm of roof I can use so plenty of space available. (could 2nd hand solar panels be used for such a system?)
would really appreciate some advise
thanks
Kris
thanks
Kris
