Any luck with this?Hello
There are several ways to start a smart BMS from Daly.
Does anyone know a way to switch it off, without disconnecting the cell cables?
Thomas
I just tried this but the voltage does not drop down to zero but it does lower it significantly. Have you tested shutting it off on your side?Turn the battery off here
Some voltage is still there, but not significant current. A real off switch like you want needs a real mechanical switch.I just tried this but the voltage does not drop down to zero but it does lower it significantly. Have you tested shutting it off on your side?
