switch/relay to reverse DC DC charger inputs --> charge starter battery
kite
Question: Is it possible to use a manual transfer switch or relay to swap the input & output of a DC - DC charger, in order to charge a starter battery from a house battery? sketch attached that I hope shows what I mean
This could be accomplished with:
- a switch like this (most are AC rated...would this be ok for 50A 12V?)
- a couple automotive relays
- a single DPDT relay like this (though I don't love the idea of always charging through some no-name amazon relay)
And a way to manually switch the charger on (in normal operating config it will automatically sense engine running). This can be done with an L-H jumper, H pin > 3V, or L switched to ground.
Any obvious reasons this will not work? Better suggestions of hardware to accomplish this?
Why:
I'm switching my van's house battery to lifepo4. The current setup has lead acid house batteries:
- charged directly from the alternator via a Blue Sea Automatic Charge Relay (parallels starter and house banks when either > 13V)
- and manual battery switch that directly parallels the house and starter batteries, allowing me to jump start from the house batteries if needed
I plan to use a Victron Orion 12-12 30A non-isolated DC-DC charger to charge the new LFP battery from the alternator. I would love to retain some way of starting/charging the starter battery from the house bank if I accidentally kill the starter.
An alternative is to use a battery switch to parallel the house and starter banks (bypassing the DC DC charger) and have a less controlled charge. The OCD part of me likes the idea of using the existing charger...I don't mind waiting a little while for the starting batt to charge.
Not a bad idea but probably easier to get a small starting maintainer like this: http://www.lslproducts.net/TLSPage.html going the other way and have a momentary booster switch with solenoid for emergency starting (Probably can wire the existing BlueSea as momentary if it has external switch control). Not sure if there would be any issues with a connection loop with two chargers and or solenoid engaged, don't think there would, I ran a amp-l-start with stock solenoid for a while.
I currently have a large Automatic BlueSea ACR with remote control switch for my AGM house but trying to figure out what I will need to change for going to LFP. My F53 gas motorhome has a 175 amp alternator and seems to have no issue supplying 80-90 amps continuous to the house but not sure how it would respond with low impedance discharged LFP's. I would like to just keep the ACR as the alternator put out about 14.1v back at the batteries and is simple and robust.
Wish someone would make a two way dc-dc charger.
Seems complicated to me. I keep a NOCO GeniusBoost 150 in my tow vehicle, connected to a 12v port. It's always ready and is an easier way to jump start another vehicle than breaking out the jumper cables.
Is this solution for when the RV is in storage?
If you keep your chassis lead acid battery charged they last at lot longer and if the RV isn't your primary vehicle yeah it becomes a storage issue. Also I had my chassis go dead due to a parasitic load while camping (think my laptop drained it off 12v plug in dash). If solar or shore power keeping chassis charged you don't have to think about it ever, nice upgrade for not much money, most motorhomes and boats have some sort of automatic charging relay to deal with this which is straight forward when the batteries are of the same chemistry.
Thanks for the responses.
Yeah, wouldn't that be nice!
To clarify, this is for a daily driver beach van + camper. I do not need a trickle charger/maintainer. The goal here is to be able to start the engine if I accidentally kill the starter battery at some remote location (say, 50 miles out dirt at a remote beach in Baja). I've used my battery combine functionality to start the engine from house bank exactly once since installing the electrical system in my van years ago and was very happy to have added this feature.
I like the idea of using the charger I'm installing to control charge. I doubt it would take long at 30A to boost the starter battery enough to start my smallish diesel.
Carrying a secondary jumper pack seems silly if I have a large LFP pack in the van...
A momentary boost switch is an option, it's just much less controlled. Current depends on voltage at both batteries, wire resistance, etc. Then if I crank the engine with them connected will I trip my 120A BMS? I don't know. Maybe it's totally fine and the simplest for the very very occasional use this will get.
Interesting thought. I believe is a 60A relay, so maybe could handle the current without cranking engine. I will check the manual and see if it can be manually switched, and if that will disable the automatic switching.
Yeah the BMS cutout could be an issue, if the chassis battery is very discharged as soon as you parallel with the LFP bank a large current will flow to the starter batt as large as the starter battery will accept which could be hundreds of amps, on top of that if you attempt to start the starter will pull a large quick surge then a good 100a continuous until engine starts. My BlueSea ACR is 500a rated so it can handle starting current or whatever. I was planning two LFP house batteries with 100a BMS so 200 continuous with probably 400 or more for a few seconds before cutout.
So perhaps just some good manual plugs to reverse charging that are accessible since it would be a rare occurrence if you really want to do a relay yeah would get a good one which could be pricy.
LFP have large capacity but their BMS's really limit their ability to jump start I think its mostly due to the mosfets used in the BMS, if it where contactors or bigger / more mosfets then they could provide starting currents without much issue.
It's a flooded lead battery - it will not accept hundreds of amps as charge. Discharge yes -hundreds or thousand amp.
As rule of thumb - a lead battery will accept about it's rated AH on A as charging current. A starter battery is 60-80AH - so it will not charge with more 60-80A (probably less when deep discharged)
Just hit the momentary switch and keep them connected for a few minutes before trying to start the engine - then the lead battery has the chance to charge and then does most of the heavy lifting and not tripping your BMS.
your picture is incomplete - the DC to DC charger is getting it's power from somewhere - and so you are potentially building a loop.
There are various ways of doing this.
I've got a Diode from the House to the Chassis battery - everytime the house battery is 0.3V above the chassis battery it's getting charged.
In your case that wouldn't work - because the DC to DC is detecting the higher voltage on the chassis battery and is starting to charge the house battery - so we just built a loop.
The same thing for DC to DC 12V battery maintainer.
Can you program then Orion DC to DC that it's only on with the engine?
How big of an alternator do you got and how big is the LFP is going to be?
If the alternator is large enough and not a massive LFP you may don't need to do anything. Just keep the existing stuff.
The loop issue is solved by cutting off the house battery charger when the starter battery charger is enabled. Easily done with a double throw relay.
The Orion can be set up to only run when alternator voltage is detected as well, but any dc charger setup should have a means to disable it when the vehicle isn't running of course.
Don't think it was mentioned whether starting battery was AGM or Flooded, my AGM's will accept 5C if discharged. Either way a dead starting battery will have a much lower voltage than the LFP's which are very stiff, current will be based on the voltage difference and the starter battery IR which will change rapidly upon paralleling the question will be if its within the BMS cutout time, I think it will easily exceed 100amps at least for a short period upon connection but honestly can't seem to find good info on the IR of a dead flooded start battery.
Don't forget you have to change the voltage profile for charging a lithium battery versus lead acid.
IMHO, the safest way to charge 3 sets of different chemistry batteries would be to use 2 separate DC-DC chargers.
Alternator --> starter battery --> DC-DC #1 --> battery 1.
Alternator --> starter battery --> DC-DC #2 --> battery 2.
AGM is different. They are much better at accepting charge. Usually most Cars and Trucks/RVs have still flooded batteries as starter battery.
Flooded lead batteries are interesting creatures, they in general have a high internal resistance - which goes up when they are fully charged, but also when they get under a certain level of charge.
Those are two different chemical effects, when the battery is getting fully charge - the electrolyte is getting saturated - resistance goes up. That's your normal charge.
When you deep discharge - you get those lead crystals forming on the plates. They initially limit the charge until they dissolve again. Looks like a U curve. Which doesn't happen in AGMs. they don't form those crystals.
The fastest a Flooded lead charges, what I've seen is at around 50-60% state of charge - around 1C.
would be also a expensive way.
Actually from people who actually try LFP + lead in parallel charging - I read that most actually complaining about the LFP not charging fast enough. Because the voltage from the alternator is to low (13.8V - 14.4V depending on the vehicle) to push large amps to LFP
In my case, starter battery is a flooded lead acid.
150A alternator
280Ah 12V lithium house battery
So the options being suggested are:
1) momentary boost switch that parallels house and starter around DC DC charger
  • pros:
    • simple, ish
  • cons:
    • uncontrolled current.
      • initial current spike might trigger BMS over current? Differing opinions here. If @eXodus is right about flooded lead acid charge acceptance rate, this is probably ok...but it's an unknown and not trivial to test.
      • fuse sizing not straight forward (likely greater than I would install if just sizing for the 30A Orion)
    • input and output of DC DC charger now connected, loop created if charger turns on. At a minimum, would need to disable the Orion automatic engine sense, and wire it to turn on when the ignition is on. Some complexity is added back in..
2) 2 x DC DC charger. NO, expensive and overkill
3) carry a lithium jumper pack. NO, expensive
4) reversing DC DC charger inputs. At this point this is my plan.
  • I like the suggestion from @jharrell about using some beefy plugs to reverse positive inputs on the rare occasion this is needed. These connectors look perfect and cheap. I can color code the normal input & output pairs (charging house bat), and reverse them to charge the starter battery.
  • I will still need to wire a jumper & switch to manually turn the charger on in the reverse use case. This is a problem I'll solve once I have it in hand and can assess all the options. Maybe I can just turn it on with bluetooth?
  • I'm not worried about the charge profile matching. Any LFP bulk charge voltage will be safe for a FLA, and it will be temporary.
Works like a charm.
manually turning on the victron orion is super simple.
  • leave engine detection on with the jumper in (it has to be in normal operation).
  • supply >3V to the H-pin (but with jumper in this is either pin) and it turns on. So I just need to add a switched wire from my 12V bus bar to the jumper.
To charge the starter battery I will:
1: disconnect the powerpole plugs on the IN and OUT of the Orion
2: plug them in with in/out reversed (colors mismatched)
3: switch on 12V to the jumper
tested and functional, though I haven't added the switch yet.
switch installed in a protected location so it doesn't get accidentally pressed. It all works as expected!
I know this is an old topic but I had the same thoughts, I'm going to do the same thing except I'm going to wire a DPDT switch in a reverse polarity configuration to switch the input and output instead of the connectors.
Am I missing the point here? If the intent is to charge the vehicle battery from the leisure battery in case the vehicle battery goes flat, wouldn't you be better off just keeping the vehicle battery topped up all the time from the leisure battery via a trickle charger that's on permanently? If you've got enough power in the leisure battery to start the vehicle, surely you have enough power to keep it topped up enough for it to start.
Are you looking to apply a solution/good idea to a problem that doesn't exist, just because it's a good idea?
yes, I think so.
I don't want to charge house battery daily (I drive it for that). I want to charge it relatively quickly the one or two times I discharge it accidentally. I solved this with a couple connectors a cheap switch that allow me to use an already installed 30A charger. Is adding a charger + extra wiring that constantly creates a charging loop (alternator/start batt -> house batt -> start batt), but will only trickle charge the start batt if I do kill it, better? Not in my opinion.
yea cool, it would be cleaner than what I did. I hope you find a good switch. I looked for a suitable switch/relay and didn't easily find one I wanted to trust indefinitely. Looks like this is what I considered:
Renogy, Ctek and Sterling offer battery to battery chargers, there may be others, that also charge the starter battery from house battery.
When the house battery is full and being charged from another source, a maintaining current is fed to the starter battery
If the requirement is to 'boost' a low/flat starter battery is an emergency situation, connect to the lithium house battery directly via a power relay, contactor, rated at 250 amps, or a battery isolator switch. Ideally use around 15 feet of AWG4 to limit the inrush current. The current into the starter battery will be much lower than expected due to lead battery self limiting.
yes, I think so.
I think I would be working out how I keep 'accidentally' discharging it and stop it ', accidentally' happening ... Trickle charging the vehicle battery isn't charging it daily, it just maintains it's charge.
Anyway, if you're happy, it doesn't matter what I think !!! If it works for you, 👍
I have a bypass relay around my Renogy 40A. Since my GM alternator is variable output ECM controlled using less than 5V, I don't have the option of 'engine running' auto control, and have to switch the DC/DC on/off manually via an 'IGN' tap at the fuse block. I also have a fused 'hot' wire from the house battery to a second switch to control the bypass relay, in case the starter battery is too low to fire the relay. With both switches lighted, and having my house battery monitor dash mounted, I can manually control what's going on. The big plus is being able to power a much bigger inverter than my house battery can power by itself by simply starting the engine and by passing the charger to supply the extra needed amps from the engine battery and alternator. The downside is having to keep the engine running until the house battery draw is under 40A so that I don't blow an alternator diode.
Just came back to this thread b/c I randomly saw a listing for a Li Time DC-DC charger that has reverse charging capability. While it looks less configurable than the Victron Orion that I installed, I definitely would have consindered installing it.
sounds like a good way to end up with two dead batteries if you accidentally leave a cab light on for a while. I have had to charge my start battery from house battery once since installing this and it worked great.
I understood your post right away, so skipped all the other post after reading misunderstood response.
I think you want to let the camper battery charge the starting battery and NOT jump start from the camper battery. Easy way is to install a 100 amp (maybe 50) A-B selector switch after the DC-DC unit (so on the rv batt side). Selecting A will keep everything as it is right now, so the DC-DC charger is connected correctly. Selecting B will bypass the DC-DC unit and connect the two batteries directly together via the B switch that is wired from B directly to starter battery and RV battery. This assumes that the negative is grounded, but if not then need two A-B switches to select B on both pos and negative, but this complicated everything, so is there a 2-pole A-B switch that selects both pos n neg at the same time from the same switch....
Switch back to A before starting vehicle as your RV batt is not meant for starting amperage.
Get really cool and add a solenoid on the starting battery side connected to ignition source so when you do start the engine that the solenoid disconnects from the RV battery. This way you cannot accidentally start with RV batt connected. This would be wired in the Normally Closed (NC) configuration I think, so is always connected unless power is cut (like when you radio turns off when you crank engine). Is fine that it is connected bc the A-B switch is what you control the connection with ayway.
Hi all.
I am resurrecting this old tread because I am trying to find a solution on the same problem.
First let's issue the previous comment. I like the idea because it will be very easy to implement. But in my van I protected all conductors with appropriately sized fuses. So pushing back to the starter battery "whatever it takes" amperes sounds a little sketchy.
Hense the idea of switching both positives. I think the two connector method that @kite took is sleek. But I really want to find a reliable off the shelf device that can do the same automatically (with the flip of a switch)
What do you guys think about a DC motor forward/reverse controller. Like the one from a 12v Winch
