I’ve got a 1S3P 1kW DC-coupled array that I am thinking about using for grid export until a power threshold is reached and then switching one panel at a time away from the Microinverter over to an SCC.
One of my 380W panels has an Isc of 11.5A, so a bit beyond what can easily and cheaply be switched with a 10A relay, but Imp is 10.96A and I’ve never gotten past 90% of the 380W rating, so I’m ready to take the risk of losing a low-cost relay or two.
The idea would be to have all 3 panels tied to the Microinverter in the morning to generate and export power until the inverter nears saturation at 580W of output.
Each 380W panel will be supplying over 190W of power when the Microinverter is maxed out at 580W, meaning current of ~1/2 Imp or ~5.5A.
So my thought is se a current switch set to 5 or 5.25A to drive a pair if 10A relays that will switch that panel from the Microinverter to the SCC.
At that point, the two remaining panels will saturate the Microinverter at a power of ~290W each or ~0.76Imp (8.4A), so a second current switch set to 8A on the second panel can switch it from the Microinverter to the Isc.
The Microinverter can always remain connected to the third panel since it will never output enough power to saturate the Microinverter.
The two relays feeding the Microinverter will never see over 10A, so should be OK.
The two relays feeding the SCC might see current of over 10A if conditions ever allow the panels to exceed 91.26% of rating (which I’ve never seen over a full year of use).
Since this 3-panel 1kW DC-coupled array is a SE-facing array with earlier output than my SW-facing 4kW grid-tied array, I’m also thinking about controlling the second panel with a current-sensor tied to output current of the larger AC-coupled array or also using a timer to only allow switchover at 12:00 when the AC-coupled array gets up past 80% of peak output.
I’m interested in anyone else who is successfully switching DC solar panel output between different energy converters.
Any advice on recommended relays or transfer switches as well as techniques that work or do not work appreciated…
