Hi everybody,
I'm facing a challenge and I'd like to consult you guys whether my thoughts are feasible and safe.
The situation: a residence is equipped with a single phase grid connection and the owner wants to install a 3 phase well pump powered by solar panels through a VFD. As the pump is not running all days, there is this idea to use the solar panels to power the home as well.
The challenge: As far as I'm aware off, there is no way to run an inverter with only one phase connected to the grid while the rest is kind of off-grid.
The solution (well it is rather theoretical): Install solar panels to feed the VFD which will run the pump on its turn. Next to it, install a single on-grid inverter to power the house when the sun is shining. A DC switch/selector will be installed between the panels on the one side and the VFD and the inverter on the other side. When the pump needs to be used, the panels will be tied with the VFD en when the pump is not needed (which is the majority of time) the VFD will be switched off and the panels will be connected to the inverter to feed the residence.
What do you think guys? Does this make sense and will it work without issues and for a long time as one would expect from a solar installation? Are you aware of any DC switch/selector with one input and two outputs?
Thanks
Thanks
