Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 23,279
Ahh, yes, a neutral can be considered a phase (even though it is actually only part of a phase), but it is a rare item indeed that uses neutral, and two hots to make use of phases...
The phases would be wrong for a 3-phase motor, maybe it would fight or show poor power factor as it put current into the oddball phase.
It would be great for a starting winding, better than a start capacitor in a single-phase induction motor.
Given those two phases you can make the 3rd phase with a couple transformers. Due to transformer voltage tolerance it won't be perfect.
If you only use two out of three phases, you have two sines, 120 degrees shifted from each other. It's not single phase, and it's not good for anything other than rectifying it, or turning one additional phase off to get single phase. Running a 3 phase device on only two of the three phases is asking for trouble.
It is single phase, riding on a common-mode sine wave
We use it all the time over here in the US. 120/208Y comes to a building (e.g. apartment complex.)
Each unit gets two hots and a neutral. Two 120V (to neutral) circuits and a 208V (L1 to L2) which is just fine for single-phase appliances like stoves, air conditioners, etc.
The rest of us use 120/240V split phase, bigger motors and heaters fed 240V but no neutral. The Big motors in the apartments get 208V but no neutral, and don't care about the common mode (104V I think.)
