I posted this in Beginner's Corner first, and then saw this forum and thought of an additional quesiton. New to this.
I'm having trouble with what seems to me to be the first question to answer: what system capacity do I need that is "just right" for my requirement: to run a 14 cubic foot electric fridge (115 V 60 Hz, 2 A) for two summer months (July-August). And add periodic load to this to run a fireplace insert blower 1.2 A only as needed during one month in early fall (September). I use propane for cooking, and have very minimal lighting needs easily satisfied with propane.
I need to consider as well that the cabin is on a small island (1.5 acres) in northern Ontario (Canada), and inaccessible in the winter months. Temperature there today is - 17 C (without the wind chill).
Questions:
1. What system capacity do I need? Is the "classic" 400 watt much more than I need? What is just right?
2. What key component choice do I need to make to conserve the possibility of a small future increase in capacity with additional batteries/panels? A few lights, for example. No plans for T.V., power tools, etc. None!
3. What about the batteries considering the location and winter storage temperatures? Cost is not my main concern. I understand Lithium may be too sensitive to consider, but I don't like the idea of storing over winter acid batteries on an island with pristine water all around. I can't remove the batteries in the fall (too many other things to do, and I'm getting old).
Thoughts?
Reply
Report Edit
Questions:
Thoughts?
Reply
Report Edit
