Brucey
Velcro Man
Blue Seas is also quality no worries there.Thanks for the information, I was planning to go with the marine blue 187 series. I will look into Bussmann or alternatives as well.
Yes, blue seas is what I meantBlue Seas is also quality no worries there.
I would add a class t fuse.Regarding the battery casing, I'm planning to create an enclosure using 15mm POM and a plexiglass cover, covering both top and front. Not closing off the sides seems to be fine, I will probably route the cables using some 3D printed parts which will cover the poles as well. The box includes all cells including the REC BMS, pre-charger as well as the shunt and the connector. Am I forgetting anything? Based on the positioning of the box I might still flip left to right as this seems to make more sense based on where the system is installed with respect to the multiplus and the rest of the electrical system. In that case I can make two holes on the left side of the box where my + and - come out.View attachment 252322
A redundant protection system is always handy.I would add a class t fuse.
Hi Frank, yes we live in Germany. We do everything electric except for heating (diesel). The battery setup is specified like this on purpose to have a bit of redundancy and buffer.Hi, I have a question barely IT.
I noticed you are from DE, in EU is not very usual to see such big battery in a "small" van.
I am genuinely curious because I have an hymer mh 7m with 100Ah,200Wp.
We (2) just made the whole eu from sicily to north cape in 4 months and found at 4% battery once, never hooked to 220V. I am fullgas and was planning to move something to electrical with bigger battery and fv. This is why I am curious, I was thinking a single 280Ah was way enough. Is your choice for redundance, are you cooking or heating via electrical?
btw..I would never do like in the picture, I'd like to have 2 separate 4s pack in a way you can cut one out with just 1 single nut reachable from outsite without dismounting the assembly. I would problably have common - and 2 + coming out of the assembly, wired as 2 4s pack inside.
Thanks for the idea, the case will be bolted directly through the floor. In the casing I will mill some small pockets for the cells to snug fit in them. Together with the clamping, this should minimise the movement. I wasn’t planning to add dampers and will use the vehicles suspension instead.I wanted some redundancy on my system, I went with two 280ah 4s batteries in my truck. Make sure you secure the cells real well, at about 12lbs each they have a lot of mass and a pot hole at speed can make them move independently causing bad connections, heat, fire. I would definitely not use solid buss bars. I mounted on 1” vibration dampers for added protection.
View attachment 252826View attachment 252827
