System Review
Calgary Sparky
Hey folks,
This is the system I am going to be installing in my rv. Just looking to get some feedback on if I have everything correct or if there is any other safety measures I should include. I have the wire sized already.
svetz
Works in theory! Practice? That's something else
Staff member
Moderator
Welcome to the forums!
I'll move this to the safety check subforum where hopefully folks will give you a thumbs up or point out a possible issue.
Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
I would suggest a DC ON/OFF Switch to allow the disconnection of the battery from the equipment. Servicing stuff & emergencies, you know.
I would use DC Breakers instead of fuses at SCC, Inverter & Charger because that acts as device disconnect but also easily resettable.
Never use cheap no name fuses or breakers, the pennies saved can kill your system & you.
m-Series - Blue Sea Systems
HRTKD
Boondocker
The 100 amp fuse/circuit breaker for the inverter may not be enough. I also have a 1,000 watt inverter. According to my manual and the calculations for wire length, I needed a 150 amp circuit breaker. Otherwise, I agree with what Steve_S suggested. The only true fuse in my system is downstream of the battery and it's a 225 amp Class T fuse.
Do you have a shore power connection? Is your inverter connected to the main AC distribution panel in the RV?
Calgary Sparky
My invertor is stand alone for very rare occasions where I need to power a small pump to refill our trailer. Pump is rated at 1/3hp so the draw is pretty low. I have bought the re-setable dc breakers also.
MisterSandals
Participation Medalist
The running "draw" might be low but the surge amps for motors and even more-so for pumps, can be 5-10x running amps.
Solutions range from bigger breakers to soft-start devices. For something that sounds like a low use item, perhaps a bigger breaker is more cost effective and safe enough.
