chicagoandy
Designing an 8S 24V with MB31s. It will have a T-Class fuse.
My question is I also need additional disconnect, and what that will be?
Let's assume a JK Inverter BMS, which will have a BMS switch. It seems like adding breakers, to be used as switches, is also common. It does feel helpful to be able to internally disconnect the battery terminals for maintenance.
Discharge: 250 amps
Charge: 100 amps
Questions.
1. Is the BMS switch sufficient to safely isolate the battery for maintenance? (I am thinking: No)
2. If not, what is the proper MCB?
Discharge: 250 amps
Charge: 100 amps
Questions.
