WorldwideDave
Solar Wizard
I have 4 different t-class fuses and 6 different fuses.
Finally got around to using the 5th t-class fuse, hooked everything up, and my system would not power up.
I measured for voltage everywhere, and thought maybe my inverter was bad, but then it turned out that actually it was the t-class fuse. Got voltage at the negative bus bar and the 'battery' side of the t-class fuse holder, but not at the other side of the t-class fuse holder. I then did a continuity 'beep' type test, and it didn't pass continuity. Swapped it out for the 6th t-class fuse, and then it started to work.
While on the bench, I was playing around with the burnt one. I do not recall seeing or hearing it ever go bad. It looks perfect on the outside. I think it is 250A rated. I never had a battery stop working charge/discharge. So I am deeply puzzled by this.
Maybe I bought a bad one/used one?
What other tests can I do with this thing?
No way visually to see that it's bad.
