JeepHammer
Solar Wizard
- Nov 15, 2019
- 1,149
Very few seem to get the idea of 'Tapping' (or Taps) in battery strings.
A 'Tap' is pulling a specific voltage from a higher voltage battery, or Series wired string of batteries.
You CAN both charge and discharge a 24 or 48 volt battery string as 12 volt batteries,
And you can do that from anywhere in the Series string.
12 Volt Batteries,
2 ea. 12 volt chargers will do a fine job charging a 24 volt Series string.
6 Volt Batteries,
4 ea. 6 volt chargers will do a fine job charging a 24 volt Series string.
This is how we 'Charge Balanced' batteries still in a string before all the high end and multi-voltage equipment came along, and in some ways gives better balancing since each battery is 'Chased' by a single charger.
Direct Current is a 'Closed Loop', a 'Circuit',
The electrical current will SEEK it's own source to complete it's own circuit, or closed loop, 'Ignoring' any other circuit connected to the same terminals.
Most people 'Assume' DC is like AC that will seek ANY 'Ground', the shortest path to 'Ground', that simply isn't the case with DC.
DC seeks it's OWN current source.
*IF* you need 12 volts from ANY battery in a 24, 36 or 48 volt Series string, you simply attach your positive & negative cables to a single 12 volt battery and draw 12 volts from it.
This WILL unbalance the batteries since you are drawing current from a single battery, but for small loads it will not unbalance the string enough to worry about.
While I don't have any fork truck batteries anymore for pictures, fork truck batteries have exposed connections between cells.
These exposed connections (also called 'Bridges') you can very effectively charge a 24 or 48 volt battery with 6 volt or 12 volt chargers simply by connecting to the appropriate number of cells.
This is a fairly common battery used in race cars, it is 16 volts at the end terminals.
While the entire battery gets an 18 volt charge, there is a 12 volt 'Tap' for sensitive electronics.
Some racing ignition systems and electronic fuel injection systems won't tolerate 16 volts, so a 12 volt Tap is provided for that sensitive equipment.
Just throwing this out there for the guys that don't know about this...
12 Volt Batteries,
6 Volt Batteries,
