Cajunwolf
First, some necessary exposition, the background information needed to understand the full scope of my question correctly. I've previously posted significantly more information in great detail in the marine forum section, but so far no one seems to have an answer. Since a marine environment can be a considered a harsh environment I thought I might try here too, and if you want to read the full description of what I'm doing here's the link to that thread.
http://www.diysolarforum.com/index.php?threads/eb-questions.135/#post-1285
The short version. I'm building a diesel-electric sailboat, a hybrid of a sort. The main auxiliary drive will be a 20kw 48VDC motor mounted in the back of the diesel, and above the shaft driving it via a cog belt. The Perkins 4-108 diesel now becomes the secondary auxiliary drive, or emergency drive and AC generator in addition to its alternator. I want to use something like Battleborn 12v 100ah LiFePO4 batteries, 12 of them in three banks of four with a total output of 300ah at 48VDC. This bank will be the primary storage bank what runs the electric auxiliary drive and ships power via inverter when not under sail. When under sail, and with the push of a button, the motor goes into regeneration mode utilizing the previously wasted drag of the spinning propeller because of the forward motion of the boat through the water supplied by the wind alone to generate free power to charge the batteries assisting the solar panels and wind turbine. Now your sailing and living on free energy being stored into your battery bank while sailing the seven seas seeking adventure.
I recently watched the video from back in July of 2018 on the Tesla comparison and was amazed; It was cheaper and better than Battleborn which was going to be $12,000 with shipping, damn! My question is, and since this is a harsh environment thread, and the saltwater and the damp environment of the seas is a harsh environment, will the Tesla battery work? Inquiring minds are eager to know.
